Critical Path and Area Based Scheduling of Parallel Task Graphs on Heterogeneous Platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Tchimou N'Takpé
  • Fonction : Auteur
  • PersonId : 836140
Frédéric Suter
While most parallel task graphs scheduling research has been done in the context of single homogeneous clusters, heterogeneous platforms have become prevalent and are extremely attractive for deploying applications at un- precedented scales. In this paper we address the need for scheduling techniques for parallel task applications for heterogeneous clusters of clusters by proposing a method to adapt existing parallel task graphs scheduling heuristics that have proved to be efficient on homogeneous environments. The contributions of this paper are: (i) a novel "virtual" cluster methodology for handling platform heterogeneity; (ii) a novel task placement step, designed to determine whether the placement step of heuristics for homogeneous platforms is adapted to the heterogeneous case; (iii) an empirical evaluation in a wide range of platform and application scenarios. This study shows that the proposed heuristics achieve better performance than the original when platform are heterogeneous and we discuss a number of trends apparent in our results.
icpads2006.pdf (331.15 Ko) Télécharger le fichier
inria-00108490 , version 1 (21-10-2006)
Tchimou N'Takpé, Frédéric Suter. Critical Path and Area Based Scheduling of Parallel Task Graphs on Heterogeneous Platforms. 12th International Conference on Parallel and Distributed Systems - ICPADS'06, Jul 2006, Minneapolis, United States. ⟨10.1109/ICPADS.2006.32⟩. ⟨inria-00108490⟩
98 Consultations
425 Téléchargements
