Document Logical Structure Analysis Based on Perceptive Cycles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Lecture Notes in Computer Science Année : 2006
Yves Rangoni
  • Fonction : Auteur
Abdel Belaïd
  • Fonction : Auteur
This paper describes a Neural Network (NN) approach for logical document structure extraction. In this NN architecture, called Transparent Neural Network (TNN), the document structure is stretched along the layers, allowing an interpretation decomposition from physical (NN input) to logical (NN output) level. The intermediate layers represent successive interpretation steps. Each neuron is apparent and associated to a logical element. The recognition proceeds by repetitive perceptive cycles propagating the information through the layers. In case of low recognition rate, an enhancement is achieved by error backpropagation leading to correct or pick up a more adapted input feature subset. Several feature subsets are created using a modified filter method. The first experiments performed on scientific documents are encouraging.
papier-local-DAS06.pdf (2.53 Mo) Télécharger le fichier
inria-00112229 , version 1 (01-12-2006)
Yves Rangoni, Abdel Belaïd. Document Logical Structure Analysis Based on Perceptive Cycles. 7th International IAPR Workshop on Document Analysis Systems - DAS 2006, Feb 2006, Nelson, New Zealand. pp.118 - 128, ⟨10.1007/11669487_11⟩. ⟨inria-00112229⟩
116 Consultations
311 Téléchargements
