Comparison-based algorithms: worst-case optimality, optimality w.r.t a bayesian prior, the intraclass-variance minimization in EDA, and implementations with billiards - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper is centered on the analysis of comparison-based algorithms. It has been shown recently that these algorithms are at most linearly convergent with a constant 1 − O(1/d); we here show that these algorithms are however optimal for robust optimization w.r.t increasing transformations of the fitness. We then turn our attention to the design of optimal comparison-based algorithms. No-Free-Lunch theorems have shown that introducing priors is necessary in order to design algorithms better than others; therefore, we include a bayesian prior in the spirit of learning theory. We show that these algorithms have a nice interpretation in terms of Estimation-Of-Distribution algorithms, and provide tools for the optimal design of generations of lambda-points by the way of billiard algorithms.
lb2.pdf (243.4 Ko) Télécharger le fichier
inria-00112813 , version 1 (09-11-2006)
  • HAL Id : inria-00112813 , version 1
Sylvain Gelly, Sylvie Ruette, Olivier Teytaud. Comparison-based algorithms: worst-case optimality, optimality w.r.t a bayesian prior, the intraclass-variance minimization in EDA, and implementations with billiards. Parallel Problem Solving from Nature BTP-Workshop, Sep 2006, Reykjavik. ⟨inria-00112813⟩
579 Consultations
144 Téléchargements
