Universal Consistency and Bloat in GP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Revue des Sciences et Technologies de l'Information - Série RIA : Revue d'Intelligence Artificielle Année : 2006
Sylvain Gelly
  • Fonction : Auteur
  • PersonId : 836546
Olivier Teytaud
Marc Schoenauer
In this paper, we provide an analysis of Genetic Programming (GP) from the Statistical Learning Theory viewpoint in the scope of symbolic regression. Firstly, we are interested in Universal Consistency, i.e. the fact that the solution minimizing the empirical error does converge to the best possible error when the number of examples goes to infinity, and secondly, we focus our attention on the uncontrolled growth of program length (i.e. bloat), which is a well-known problem in GP. Results show that (1) several kinds of code bloats may be identified and that (2) Universal consistency can be obtained as well as avoiding bloat under some con- ditions. We conclude by describing an ad hoc method that makes it possible simultaneously to avoid bloat and to ensure universal consistency.
riabloat.pdf (173.82 Ko) Télécharger le fichier
inria-00112840 , version 1 (10-11-2006)
  • HAL Id : inria-00112840 , version 1
Sylvain Gelly, Olivier Teytaud, Nicolas Bredeche, Marc Schoenauer. Universal Consistency and Bloat in GP. Revue des Sciences et Technologies de l'Information - Série RIA : Revue d'Intelligence Artificielle, 2006. ⟨inria-00112840⟩
418 Consultations
456 Téléchargements
