Generalizing a Proof-Theoretic Account of Scope Ambiguity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
When trying to build the semantic representation of a natural language expression, it may happen that a single expression produces many semantic representations. In this paper, we focus on scope ambiguities where a single syntactic analysis can yield many semantic representations. There are basically two ways to address scope ambiguities. One way is to build two syntactic structures (parse trees) from a single expression, then, from these syntactic structures, to functionally build two semantic representations. The other way is to build a single syntactic structure and to associate to the latter, in a non-functional way, two semantic representations. These two ways are represented by two frameworks: the type-logical framework, where ambiguity is modeled by the process (proof search), and the underspecification framework, where ambiguity is modeled by a (formal) language. Our proposal aims at giving a proof-theoretic account of scope ambiguity that does not rely on syntactic ambiguity nor on another intermediate language. It is based on the Abstract Categorial Grammar (ACG) framework.
pogodalla.pdf (148.61 Ko) Télécharger le fichier
inria-00112898 , version 1 (10-12-2006)
inria-00112898 , version 2 (13-12-2006)
inria-00112898 , version 3 (21-05-2007)
  • HAL Id : inria-00112898 , version 1
Sylvain Pogodalla. Generalizing a Proof-Theoretic Account of Scope Ambiguity. 7th International Workshop on Computational Semantics - IWCS-7, Jan 2007, Tilburg/The Netherlands. ⟨inria-00112898v1⟩
242 Consultations
169 Téléchargements
