Termination of rewriting under strategies: a generic approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) ACM Transactions on Computational Logic Année : 2006
We propose a synthesis of three induction based algorithms, we already have given to prove termination of rewrite rule based programs, respectively for the innermost, the outermost and the local strategies. A generic inference principle is presented, based on an explicit induction on the termination property, which genetates ordering constraints, defining the induction relation. The generic inference principle is then instantiated to provide proof procedures for the three specific considered strategies.
tocl-second-version-hal.pdf (526.92 Ko) Télécharger le fichier
inria-00113156 , version 1 (10-11-2006)
  • HAL Id : inria-00113156 , version 1
Isabelle Gnaedig, Hélène Kirchner. Termination of rewriting under strategies: a generic approach. [Research Report] 2006. ⟨inria-00113156⟩
115 Consultations
95 Téléchargements
