Symplectic integrators in sub-Riemannian geometry: the Martinet case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We compare the performances of symplectic and non-symplectic integrators for the computation of normal geodesics and conjugate points in sub-Riemannian geometry at the example of the Martinet case. For this case study we consider first the flat metric, and then a one parameter perturbation leading to non integrable geodesics. From our computations we deduce that near the abnormal directions a symplectic method is much more efficient for this optimal control problem. The explanation relies on the theory of backward error analysis in geometric numerical integration.
RR-6017.pdf (282.94 Ko) Télécharger le fichier
inria-00113372 , version 1 (13-11-2006)
inria-00113372 , version 2 (13-11-2006)
Monique Chyba, Ernst Hairer, Gilles Vilmart. Symplectic integrators in sub-Riemannian geometry: the Martinet case. [Research Report] RR-6017, INRIA. 2006, pp.10. ⟨inria-00113372v2⟩
265 Consultations
95 Téléchargements
