Preserving first integrals and volume forms of additively split systems - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2006
This work is concerned with the preservation of invariants and of volume-forms by numerical methods which can be expanded into B-series. The situation we consider here is that of a split vector field where each sub-field either has the common invariant I or is divergence free. We derive algebraic conditions on the coefficients of the B-series for it either to preserve I or to preserve the volume for generic vector fields and interpret them for additive Runge-Kutta methods. Comparing the two sets of conditions then enables us to state some non-existence results. For a more restrictive class of problems, where the system is partitionned into several components, we nevertheless obtain simplified conditions and show that they can be solved.
Rainvpres06.pdf (217.86 Ko) Télécharger le fichier
Dates and versions
inria-00113486 , version 1 (13-11-2006)
inria-00113486 , version 2 (13-11-2006)
Identifiers
  • HAL Id : inria-00113486 , version 1
Cite
Philippe Chartier, Murua Ander. Preserving first integrals and volume forms of additively split systems. [Research Report] 2006, pp.27. ⟨inria-00113486v1⟩
198 View
244 Download
Share
