Formalising Sylow's theorems in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2006
Laurent Théry
Laurence Rideau
  • Fonction : Auteur
  • PersonId : 832430
This report presents a formalisation of Sylow's theorems done in Coq. The formalisation has been done in a couple of weeks on top of Georges Gonthier's ssreflect. There were two ideas behind formalising Sylow's theorems. The first one was to get familiar with Georges way of doing proofs. The second one was to contribute to the collective effort to formalise a large subset of group theory in Coq with some non-trivial proofs.
Sylow.pdf (211.34 Ko) Télécharger le fichier
inria-00113750 , version 1 (14-11-2006)
inria-00113750 , version 2 (22-11-2006)
Laurent Théry, Laurence Rideau. Formalising Sylow's theorems in Coq. [Technical Report] 2006, pp.23. ⟨inria-00113750v1⟩
393 Consultations
313 Téléchargements
