A structural approach for 3D building reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this report, we present a 3D building reconstruction method based on a structural approach. It consists in reconstructing buildings by assembling simple urban structures extracted from a grammar of 3D parametric models. This method is composed of two stages. The first one, which has already been tackled in previous works, consists in extracting the building footprints through configurations of connected quadrilaterals. The second stage, detailed in this report, corresponds to the 3D reconstruction from DEMs and obtained building footprints. An energy formulation is used within a Bayesian framework which is particularly well adapted to introduce prior knowledge related to urban structures and their assembling. In order to find the optimal solution of this energy, two different optimization techniques are used and compared.
RR-INRIA_Lafarge.pdf (2.79 Mo) Télécharger le fichier
inria-00114338 , version 1 (16-11-2006)
inria-00114338 , version 2 (06-12-2006)
  • HAL Id : inria-00114338 , version 1
Florent Lafarge, Xavier Descombes, Josiane Zerubia, Marc Pierrot-Deseilligny. A structural approach for 3D building reconstruction. [Research Report] 2006. ⟨inria-00114338v1⟩
200 Consultations
314 Téléchargements
