Construction of simple, stable and convergent high order schemes for steady first order Hamilton Jacobi equations. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We develop a very simple algorithm that permits to construct compact, high order schemes for steady first order Hamilton Jacobi equations. The algorithm relies on the blending of a first order scheme and a compact high order one. The blending is conducted in such a way that the scheme is formally high order accurate. A convergence proof is given. We provide several numerical illustrations that demonstrate the effective accuracy of the scheme. The numerical examples use triangular unstructured meshes, but our method may be applied to other kind of meshes. Several implementation remarks are also given.
hjheigh.pdf (721.03 Ko) Télécharger le fichier
inria-00114888 , version 1 (18-11-2006)
inria-00114888 , version 2 (06-12-2006)
inria-00114888 , version 3 (07-12-2006)
inria-00114888 , version 4 (07-12-2006)
  • HAL Id : inria-00114888 , version 1
Remi Abgrall. Construction of simple, stable and convergent high order schemes for steady first order Hamilton Jacobi equations.. [Research Report] 2006, pp.34. ⟨inria-00114888v1⟩
67 Consultations
245 Téléchargements
