Closed-loop parametric identification for continuous-time linear systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2007
Closed-loop parametric identification of continuous-time linear systems is achieved via new algebraic techniques, which are employing non-commutative ring theory, module theory, and operational calculus. The efficiency and robustness with respect to noises are demonstrated by three illustrative examples and their computer simulations. In two of them we compare our results with those given by standard adaptive methods.
chapter-Fliess-Sira.pdf (659.81 Ko) Télécharger le fichier
inria-00114958 , version 1 (19-11-2006)
inria-00114958 , version 2 (20-01-2007)
inria-00114958 , version 3 (17-03-2007)
  • HAL Id : inria-00114958 , version 2
Michel Fliess, Hebertt Sira-Ramirez. Closed-loop parametric identification for continuous-time linear systems. H. Garnier and L. Wang. Continuous-Time Model Identification from Sampled Data, Springer, 2007. ⟨inria-00114958v2⟩
623 Consultations
1361 Téléchargements
