Efficient Selectivity and Backup Operators in Monte-Carlo Tree Search
Monte-Carlo evaluation consists in estimating a position by averaging the outcome of several random continuations, and can serve as an evaluation function at the leaves of a min-max tree. This paper presents a new framework to combine tree search with Monte-Carlo evaluation, that does not separate between a min-max phase and a Monte-Carlo phase. Instead of backing-up the min-max value close to the root, and the average value at some depth, a more general backup operator is defined that progressively changes from averaging to min-max as the number of simulations grows. This approach provides a fine-grained control of the tree growth, at the level of individual simulations, and allows efficient selectivity methods. This algorithm was implemented in a Go-playing program, Crazy Stone, that won the gold medal of the $9 \times 9$ Go tournament at the 11th Computer Olympiad.
Domains
Machine Learning [cs.LG]
Origin : Publisher files allowed on an open archive
