OpenDP a free Reinforcement Learning toolbox for discrete time control problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Sylvain Gelly
  • Fonction : Auteur
  • PersonId : 836546
Olivier Teytaud
OpenDP (http://opendp.sourceforge.net) is a free software (under GPL) written in C++ for control problems: (i) with discrete time steps (either finite horizon, or approximation of infinite horizon by temporal-ring for stationnary problems), (ii) where the transition function newState = T (state, decision) can be encoded in C++, (iii) possibly stochastic (with the function T above depending on some random process).
openDP_NIPS.pdf (30.16 Ko) Télécharger le fichier
inria-00117392 , version 1 (01-12-2006)
  • HAL Id : inria-00117392 , version 1
Sylvain Gelly, Olivier Teytaud. OpenDP a free Reinforcement Learning toolbox for discrete time control problems. NIPS Workshop on Machine Learning Open Source Software, Dec 2006, Whistler (B.C.). ⟨inria-00117392⟩
352 Consultations
90 Téléchargements
