A Formalization of the Theory of Objects in Isabelle/HOL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We present a formalization of Abadi's and Cardelli's theory of objects in the interactive theorem prover Isabelle/HOL. In particular, we present (a) a formal model of objects and its operational semantics based on DeBruijn indices (b) a parallel reduction relation for objects (c) the proof of confluence for the theory of objects reusing Nipkow's HOL-framework for the lambda calculus.
RR-Sigma.pdf (292.83 Ko) Télécharger le fichier
inria-00121816 , version 1 (22-12-2006)
inria-00121816 , version 2 (06-02-2007)
  • HAL Id : inria-00121816 , version 1
Ludovic Henrio, Florian Kammüller. A Formalization of the Theory of Objects in Isabelle/HOL. [Research Report] RR-6079, 2006, pp.20. ⟨inria-00121816v1⟩
Collections
INRIA-RRRT
246 Consultations
188 Téléchargements
