Maximum Level and Hitting Probabilities in Stochastic Fluid Flows using Matrix Differential Riccati Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bruno Sericola
In this work, we expose a clear methodology to analyze maximum level and hitting probabilities in a Markov driven fluid queue for various initial condition scenarios and in both cases of infinite and finite buffers. Step by step we build up our argument that finally leads to matrix differential Riccati equations for which there exists a unique solution. The power of the methodology resides in the simple probabilistic argument used that permits to obtain analytic solutions of these differential equations. We illustrate our results by a comprehensive fluid model that we exactly solve.
pub_inria.pdf (285.47 Ko) Télécharger le fichier
inria-00123245 , version 1 (08-01-2007)
inria-00123245 , version 2 (11-01-2007)
inria-00123245 , version 3 (26-06-2007)
  • HAL Id : inria-00123245 , version 2
Bruno Sericola, Marie-Ange Remiche. Maximum Level and Hitting Probabilities in Stochastic Fluid Flows using Matrix Differential Riccati Equations. [Research Report] 2007. ⟨inria-00123245v2⟩
211 Consultations
185 Téléchargements
