Non-functional property analysis using UML2.0 and model transformations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Real-time embedded architectures consist of software and hardware parts. Meeting non-functional constraints (e.g., real-time constraints) greatly depends on the mappings from the system functionalities to software and hardware components. Thus, there is a strong demand for precise architecture and allocation modeling, amenable to performance analysis. The report proposes a model-driven approach for the assessment of the quality of allocations of the system functionalities to the architecture. We consider two technical domains: the UML domain for the definition of the model elements (for both description and analysis), and an analysis domain, external to UML, used for formal verification. This report defines three meta-models, one for each domain, and provides automated transformations within and between these domains. A special attention is then paid to temporal property analysis, based on a particular analysis model: the Modular and Hierarchical Time Petri Nets.
RR-5913.pdf (390.14 Ko) Télécharger le fichier
inria-00124874 , version 1 (16-01-2007)
  • HAL Id : inria-00124874 , version 1
Charles André, Frédéric Mallet, Marie-Agnès Peraldi-Frati. Non-functional property analysis using UML2.0 and model transformations. [Research Report] RR-5913, INRIA. 2006, pp.18. ⟨inria-00124874⟩
139 Consultations
160 Téléchargements
