Simulation of a diffusion process by using the importance sampling paradigm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2007
We construct in this paper a Monte Carlo method in order to approach solutions of multi-dimensional Stochastic Differential Equations processes which relies on the importance sampling technique. Our method is based on the random walk on squares/rectangles method and the main interest of this construction is that the weights are easily computed from the density of the one-dimensional Brownian motion. The advantage we take on the Euler scheme is that this method allows us to get a better simulation of diffusions when one has really to take care of the boundary conditions. Moreover, it provides a good alternative to perform variance reduction techniques and simulation of rare events.
deaconu-lejay-walk-on-rectangles-2007.pdf (270.29 Ko) Télécharger le fichier
inria-00126339 , version 1 (24-01-2007)
inria-00126339 , version 2 (19-11-2009)
  • HAL Id : inria-00126339 , version 1
Madalina Deaconu, Antoine Lejay. Simulation of a diffusion process by using the importance sampling paradigm. The Annals of Applied Probability, 2007. ⟨inria-00126339v1⟩
200 Consultations
360 Téléchargements
