Time- and Space-Efficient Evaluation of Some Hypergeometric Constants - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The currently best known algorithms for the numerical evaluation of hypergeometric constants such as $\zeta(3)$ to $d$ decimal digits have time complexity $O(M(d) \log^2 d)$ and space complexity of $O(d \log d)$ or $O(d)$. Following work from Cheng, Gergel, Kim and Zima, we present a new algorithm with the same asymptotic complexity, but more efficient in practice. Our implementation of this algorithm improves slightly over existing programs for the computation of $\pi$, and we announce a new record of 2 billion digits for $\zeta(3)$.
RR-6105.pdf (237.58 Ko) Télécharger le fichier
inria-00126428 , version 1 (25-01-2007)
inria-00126428 , version 2 (25-01-2007)
Howard Cheng, Guillaume Hanrot, Emmanuel Thomé, Eugene Zima, Paul Zimmermann. Time- and Space-Efficient Evaluation of Some Hypergeometric Constants. [Research Report] RR-6105, INRIA. 2007. ⟨inria-00126428v2⟩
220 Consultations
224 Téléchargements
