A GMP-based implementation of Schönhage-Strassen's large integer multiplication algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Other Publications Year : 2007
Schönhage-Strassen's algorithm is one of the best known algorithms for multiplying large integers. Implementing it efficiently is of utmost importance, since many other algorithms rely on it as a subroutine. We present here an improved implementation, based on the one distributed within the GMP library. The following ideas and techniques were used or tried: faster arithmetic modulo $2^n+1$, improved cache locality, Mersenne transforms, Chinese Remainder Reconstruction, the $\sqrt{2}$ trick, Harley's and Granlund's tricks, improved tuning. We also discuss some ideas we plan to try in the future.
fft.pdf (278.86 Ko) Télécharger le fichier
Dates and versions
inria-00126462 , version 1 (25-01-2007)
inria-00126462 , version 2 (23-05-2007)
Identifiers
  • HAL Id : inria-00126462 , version 1
Cite
Pierrick Gaudry, Alexander Kruppa, Paul Zimmermann. A GMP-based implementation of Schönhage-Strassen's large integer multiplication algorithm. 2007. ⟨inria-00126462v1⟩
848 View
3651 Download
Share
