WDM and Directed Star Arboricity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A digraph is {\it $m$-labelled} if every arcs is labelled by an integer in $\{1, \dots ,m\}$. Motivated by wavelength assignment for multicasts in optical star networks, we study {\it $n$-fiber colourings} of labelled digraph which are colourings of the arcs of $D$ such that at each vertex $v$, for each colour $\lambda$, $in(v,\lambda)+out(v,\lambda)\leq n$ with $in(v,\lambda)$ the number of arcs coloured $\lambda$ entering $v$ and $out(v,\lambda)$ the number of labels $l$ such that there exists an arc leaving $v$ of label $l$ coloured $\lambda$. One likes to find the minimum number of colours $\lambda_n(D)$ such that an $m$-labbelled digraph $D$ has an $n$-fiber colouring. In the particular case, when $D$ is $1$-labelled then $\lambda_n(D)$ is the {\it directed star arboricty} of $D$, denoted $dst(D)$. We first show that $dst(D)\leq 2\Delta^-(D)+1$ and conjecture that if $\Delta^-(D)\geq 2$ then $dst(D)\leq 2\Delta^-(D)$. We also prove that if $D$ is subcubic then $dst(D)\leq 3$ and that if $\Delta^+(D), \Delta^-(D)\leq 2$ then $dst(D)\leq 4$. Finally, we study $\lambda_n(m,k)=\max\{\lambda_n(D) \tq D \mbox{ is $m$-labelled} \et \Delta^-(D)\leq k\}$. We show that if $m\geq n$ then $\ds \left\lceil\frac{m}{n}\left\lceil \frac{k}{n}\right\rceil + \frac{k}{n} \right\rceil\leq \lambda_n(m,k) \leq\left\lceil\frac{m}{n}\left\lceil \frac{k}{n}\right\rceil + \frac{k}{n} \right\rceil + C \frac{m^2\log k}{n} \mbox {\ \ \ \ \ for some constant $C$.}$
RR-6179.pdf (335.93 Ko) Télécharger le fichier
inria-00132396 , version 1 (21-02-2007)
inria-00132396 , version 2 (02-05-2007)
inria-00132396 , version 3 (03-05-2007)
  • HAL Id : inria-00132396 , version 3
  • ARXIV : 0705.0315
Omid Amini, Frédéric Havet, Florian Huc, Stéphan Thomassé. WDM and Directed Star Arboricity. [Research Report] RR-6179, INRIA. 2007, pp.20. ⟨inria-00132396v3⟩
437 Consultations
145 Téléchargements
