Organization of the Modulopt collection of optimization problems in the Libopt environment -- Version 1.0 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2007
This note describes how the optimization problems of the Modulopt collection are organized within the Libopt environment. It is aimed at being a guide for using and enriching this collection in this environment.
RT-0312.pdf (254.28 Ko) Télécharger le fichier
inria-00132468 , version 1 (23-02-2007)
inria-00132468 , version 2 (26-02-2007)
inria-00132468 , version 3 (02-03-2007)
Jean Charles Gilbert. Organization of the Modulopt collection of optimization problems in the Libopt environment -- Version 1.0. [Technical Report] RT-0312, 2007, pp.20. ⟨inria-00132468v2⟩
Collections
INRIA-RRRT
81 Consultations
53 Téléchargements
