A new symmetric extension of FGM copulas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a new family of copulas generalizing the Farlie-Gumbel-Morgenstern (FGM) family and generated by two univariate functions. The main feature of this family is two permit the modeling of high positive dependence. In particular, it is established that the correlation range is [-3/4,1] and that the upper tail dependence coefficient can reach any value in [0,1]. Some examples of parametric subfamilies are provided.
amblard_girard.pdf (148.96 Ko) Télécharger le fichier
inria-00134433 , version 1 (02-03-2007)
inria-00134433 , version 2 (08-02-2008)
  • HAL Id : inria-00134433 , version 1
Cécile Amblard, Stéphane Girard. A new symmetric extension of FGM copulas. [Research Report] 2007, pp.20. ⟨inria-00134433v1⟩
Collections
TIMC-IMAG
1486 Consultations
1008 Téléchargements
