LIBOPT - An environment for testing solvers on heterogeneous collections of problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2007
The Libopt environment is both a methodology and a set of tools that can be used for testing, comparing, and profiling solvers on problems belonging to various collections. These collections can be heterogeneous in the sense that their problems can have common features that differ from one collection to the other. Libopt brings a unified view on this composite world by offering, for example, the possibility to run any solver on any problem compatible with it, using the same Unix/Linux command. The environment also provides tools for comparing the results obtained by solvers on a specified set of problems. Most of the scripts going with the Libopt environment have been written in Perl.
RT-0331.pdf (318.31 Ko) Télécharger le fichier
inria-00135013 , version 1 (06-03-2007)
inria-00135013 , version 2 (12-03-2007)
Paternité
Jean Charles Gilbert, Xavier Jonsson. LIBOPT - An environment for testing solvers on heterogeneous collections of problems. [Technical Report] RT-0331, INRIA. 2007, pp.35. ⟨inria-00135013v2⟩
182 Consultations
167 Téléchargements
