Cosmological Simulations using Grid Middleware - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Large problems ranging from numerical simulation can now be solved through the Internet using grid middleware. This report describes the different steps involved to make available a service in the DIET grid middleware. The cosmological RAMSES application is taken as an example to detail the implementation. Furthermore, several results are given in order to show the benefits of using DIET, among which the transparent usage of numerous clusters and a low overhead (finding the right resource and submitting the computing task).
RR-6139.pdf (410.05 Ko) Télécharger le fichier
inria-00135189 , version 1 (07-03-2007)
inria-00135189 , version 2 (12-03-2007)
inria-00135189 , version 3 (12-03-2007)
  • HAL Id : inria-00135189 , version 2
Yves Caniou, Eddy Caron, Benjamin Depardon, Hélène M. Courtois, Romain Teyssier. Cosmological Simulations using Grid Middleware. [Research Report] RR-6139, 2007, pp.24. ⟨inria-00135189v2⟩
Collections
INRIA-RRRT
353 Consultations
293 Téléchargements
