Online data processing: comparison of Bayesian regularized particle filters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Journal of Statistics Année : 2009
The aim of this paper is to compare three regularized particle filters in an online data processing context. We carry out the comparison in terms of hidden states filtering and parameters estimation, considering a Bayesian paradigm and a univariate stochastic volatility model. We discuss the use of an improper prior distribution in the initialization of the filtering procedure and show that the Regularized Auxiliary Particle Filter (R-APF) outperforms the Regularized Sequential Importance Sampling (R-SIS) and the Regularized Sampling Importance Resampling (R-SIR).
RR-6153.pdf (1.58 Mo) Télécharger le fichier
inria-00138007 , version 1 (23-03-2007)
inria-00138007 , version 2 (26-03-2007)
inria-00138007 , version 3 (04-03-2008)
Roberto Casarin, Jean-Michel Marin. Online data processing: comparison of Bayesian regularized particle filters. Electronic Journal of Statistics , 2009, 3, pp.239-258. ⟨10.1214/08-EJS256⟩. ⟨inria-00138007v3⟩
149 Consultations
985 Téléchargements
