Asynchronism Induces Second Order Phase Transitions in Elementary Cellular Automata - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Cellular Automata Année : 2008
Nazim A. Fatès
Cellular automata are widely used to model natural systems. Classically they are run with perfect synchrony, {\em i.e.}, the local rule is applied to each cell at each time step. A possible odification of the updating scheme consists in applying the rule with a fixed probability, called the synchrony rate. For some particular rules, varying the synchrony rate continuously produces a discontinuity in the behaviour of the cellular automaton. We investigate the nature of this change of behaviour using Monte-Carlo simulations. We apply a two-step protocol to show that the change of behaviour is a phase transition whose critical exponents are in good agreement with the predicted values of directed percolation and parity conservation universality classes.
Percolation.pdf (194.21 Ko) Télécharger le fichier
inria-00138051 , version 1 (23-03-2007)
inria-00138051 , version 2 (09-01-2008)
inria-00138051 , version 3 (13-02-2008)
Nazim A. Fatès. Asynchronism Induces Second Order Phase Transitions in Elementary Cellular Automata. Journal of Cellular Automata, 2008. ⟨inria-00138051v2⟩
435 Consultations
477 Téléchargements
