Primality Proving with Elliptic Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Laurent Théry
Elliptic curves are fascinating mathematical objects. In this paper, we present the way they have been represented inside the {\sc Coq} system, and how we have proved that the classical composition law on the points is internal and gives them a group structure. We then describe how having elliptic curves inside a prover makes it possible to derive a checker for proving the primality of natural numbers.
paper.pdf (171.02 Ko) Télécharger le fichier
inria-00138382 , version 1 (26-03-2007)
inria-00138382 , version 2 (09-04-2007)
  • HAL Id : inria-00138382 , version 1
Laurent Théry, Guillaume Hanrot. Primality Proving with Elliptic Curves. [Research Report] RR-6155, 2007. ⟨inria-00138382v1⟩
Collections
INRIA-RRRT
1633 Consultations
659 Téléchargements
