A Modular Formalisation of Finite Group Theory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Assia Mahboubi
Laurence Rideau
  • Fonction : Auteur
  • PersonId : 832430
Laurent Théry
In this paper, we present a formalisation of elementary group theory done in Coq. This work is the first milestone of a long-term effort to formalise Feit-Thompson theorem. As our further developments will heavily rely on this initial base, we took special care to articulate it in the most compositional way.
RR-6156.pdf (235.7 Ko) Télécharger le fichier
inria-00139131 , version 1 (29-03-2007)
inria-00139131 , version 2 (03-04-2007)
  • HAL Id : inria-00139131 , version 2
Georges Gonthier, Assia Mahboubi, Laurence Rideau, Enrico Tassi, Laurent Théry. A Modular Formalisation of Finite Group Theory. [Research Report] RR-6156, INRIA. 2007, pp.17. ⟨inria-00139131v2⟩
820 Consultations
856 Téléchargements
