An Interactive Problem Modeller and PDE Solver, Distributed on Large Scale Architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Hervé Frezza-Buet
Jens Gustedt
Stéphane Vialle
This paper introduces a research project and a software environment to speed up and size up problem modeling with Partial Differential Equations (PDE). These PDE are defined from a \Mathematica interface, and are automatically solved by a devoted cellular automata program generated to be run on mainframes, clusters and Grids. Moreover, an interactive and graphic control of the cellular automata running allows to analyze the PDE model relevance. This environment improves large scale simulation usage in early stages of research projects.
dfma-paper.pdf (178.92 Ko) Télécharger le fichier
inria-00139660 , version 1 (23-11-2007)
  • HAL Id : inria-00139660 , version 1
Nicolas Fressengeas, Hervé Frezza-Buet, Jens Gustedt, Stéphane Vialle. An Interactive Problem Modeller and PDE Solver, Distributed on Large Scale Architectures. Third International Workshop on Distributed Frameworks for Multimedia Applications - DFMA '07, Jun 2007, Paris, France. ⟨inria-00139660⟩
381 Consultations
204 Téléchargements
