The Vlasov-Maxwell system with strong initial magnetic field. Part II : Finite Larmor radius regime - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study here the finite Larmor radius regime for the Vlasov-Maxwell equations with strong initial magnetic field. The proofs follow by the modulated energy technique. We establish convergence results for the electro-magnetic field and we justify rigorously the limit for the circle center distribution.
RR-6159.pdf (224.35 Ko) Télécharger le fichier
inria-00139666 , version 1 (02-04-2007)
inria-00139666 , version 2 (05-04-2007)
inria-00139666 , version 3 (25-04-2007)
inria-00139666 , version 4 (18-02-2008)
inria-00139666 , version 5 (20-02-2008)
  • HAL Id : inria-00139666 , version 2
Mihai Bostan. The Vlasov-Maxwell system with strong initial magnetic field. Part II : Finite Larmor radius regime. [Research Report] RR-6159, 2007. ⟨inria-00139666v2⟩
Collections
INRIA-RRRT CERMICS
194 Consultations
561 Téléchargements
