Normalization in Supernatural deduction and in Deduction modulo
Deduction modulo and Supernatural deduction are two extentions of predicate logic with computation rules. Whereas the application of computation rules in deduction modulo is transparent, these rules are used to build non-logical deduction rules in Supernatural deduction. In both cases, adding computation rules may jeopardize proof normalization, but various conditions have been given in both cases, so that normalization is preserved. We prove in this paper that normalization in Supernatural deduction and in Deduction modulo are equivalent, i.e. the set of computation rules for which one system strongly normalizes is the same as the set of computation rules for which the other is.
