A revised look at numerical differentiation with an application to nonlinear feedback control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We are presenting new and efficient methods for numerical differentiation, i.e., for estimating derivatives of a noisy time signal. They are illustrated, via convincing numerical simulations, by the analysis of an academic signal and by the feedback control of a nonlinear system.
derive_R1.pdf (253.4 Ko) Télécharger le fichier
inria-00142588 , version 1 (19-04-2007)
  • HAL Id : inria-00142588 , version 1
Mamadou Mboup, Cédric Join, Michel Fliess. A revised look at numerical differentiation with an application to nonlinear feedback control. The 15th Mediterrean Conference on Control and Automation - MED'2007, Jun 2007, Athènes, Greece. ⟨inria-00142588⟩
568 Consultations
1177 Téléchargements
