Evolving Symbolic Controllers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The idea of symbolic controllers tries to bridge the gap between the top-down manual design of the controller architecture, as advocated in Brooks' subsumption architecture, and the bottom-up designer-free approach that is now standard within the Evolutionary Robotics community. The designer provides a set of elementary behavior, and evolution is given the goal of assembling them to solve complex tasks. Two experiments are presented, demonstrating the efficiency and showing the recursiveness of this approach. In particular, the sensitivity with respect to the proposed elementary behaviors, and the robustness w.r.t. generalization of the resulting controllers are studied in detail.
Mots clés
evorobRevised.pdf (179.68 Ko) Télécharger le fichier
inria-00145206 , version 1 (09-05-2007)
  • HAL Id : inria-00145206 , version 1
  • ARXIV : 0705.1244
Nicolas Godzik, Marc Schoenauer, Michèle Sebag. Evolving Symbolic Controllers. 4th European Workshop on Evolutionary Robotics, Apr 2003, Essex, United Kingdom. pp.638-650. ⟨inria-00145206⟩
223 Consultations
154 Téléchargements
