Elementary transformation analysis for Array-OL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Array-OL is a high-level specification language dedicated to the definition of intensive signal processing applications. Several tools exist for implementing an Array-OL specification as a data parallel program. While Array-OL can be used directly, it is often convenient to be able to deduce part of the specification from a sequential version of the application. This paper proposes such an analysis and examines its feasibility and its limits.
RR-6193.pdf (144.84 Ko) Télécharger le fichier
inria-00146323 , version 1 (14-05-2007)
inria-00146323 , version 2 (22-05-2007)
inria-00146323 , version 3 (22-05-2007)
  • HAL Id : inria-00146323 , version 2
  • ARXIV : 0705.2145
Paul Feautrier. Elementary transformation analysis for Array-OL. [Research Report] RR-6193, 2007, pp.12. ⟨inria-00146323v2⟩
Collections
INRIA-RRRT
119 Consultations
98 Téléchargements
