Rewrite Rules and Strategies for Molecular Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2007
In this paper, we present a rewriting framework for modeling molecular complexes, biochemical reaction rules and generation of biochemical networks based on the representation of molecular complexes as a particular type of multigraphs with ports called molecular graphs. The advantage of this approach is to obtain for free a rewriting calculus which allows defining at the same level transformation rules and strategies for modeling rule selection and application, in order to prototype network generation.
AndreiKirchner-CMSB.pdf (343.07 Ko) Télécharger le fichier
inria-00146362 , version 1 (14-05-2007)
inria-00146362 , version 2 (03-07-2007)
inria-00146362 , version 3 (12-11-2007)
  • HAL Id : inria-00146362 , version 1
Oana Andrei, Hélène Kirchner. Rewrite Rules and Strategies for Molecular Graphs. 2007. ⟨inria-00146362v1⟩
94 Consultations
321 Téléchargements
