Modeling of Topologies of Interconnection Networks based on Multidimensional Multiplicity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Modern SoCs are becoming more complex with the integration of heterogeneous components (IPs). For this purpose, a high performance interconnection medium is required to handle the complexity. Hence NoCs come into play enabling the integration of more IPs into the SoC with increased performance. These NoCs are based on the concept of Interconnection networks used to connect parallel machines. In response to the MARTE RFP of the OMG, a notation of multidimensional multiplicity has been proposed which permits to model repetitive structures and topologies. This report presents a modeling methodology based on this notation that can be used to model a family of Interconnection Networks called Delta Networks which in turn can be used for the construction of NoCs.
RR.pdf (770.55 Ko) Télécharger le fichier
inria-00149527 , version 1 (25-05-2007)
inria-00149527 , version 2 (28-05-2007)
inria-00149527 , version 3 (31-05-2007)
inria-00149527 , version 4 (21-06-2007)
  • HAL Id : inria-00149527 , version 1
Imran Rafiq Quadri, Pierre Boulet, Jean-Luc Dekeyser. Modeling of Topologies of Interconnection Networks based on Multidimensional Multiplicity. [Research Report] 2007. ⟨inria-00149527v1⟩
233 Consultations
2266 Téléchargements
