Une sémantique observationnelle du modèle des boîtes pour la résolution de programmes logiques (version étendue) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2007
Pierre Deransart
  • Fonction : Auteur
  • PersonId : 833574
Mireille Ducassé
This report specifies an observational semantics and gives an original presentation of the Byrd's box model. The approach accounts for the semantics of Prolog tracers independently of a particular implementation. Traces are, in general, considered as rather obscure and difficult to use. The proposed formal presentation of a trace constitutes a simple and pedagogical approach for teaching Prolog or for implementing Prolog tracers. It constitutes a form of declarative specification for the tracers. Our approach highlights qualities of the box model which made its success, but also its drawbacks and limits. As a matter of fact, the presented semantics is only one example to illustrate general problems relating to tracers and observing processes. Observing processes know, from observed processes, only their traces. The issue is then to be able to reconstitute by the sole analysis of the trace the main part of the observed process, and if possible, without any loss of information.
rapport.pdf (564.86 Ko) Télécharger le fichier
inria-00151285 , version 1 (03-06-2007)
inria-00151285 , version 2 (21-06-2007)
inria-00151285 , version 3 (25-06-2007)
  • HAL Id : inria-00151285 , version 2
  • ARXIV : 0706.3159
Pierre Deransart, Mireille Ducassé, Gérard Ferrand. Une sémantique observationnelle du modèle des boîtes pour la résolution de programmes logiques (version étendue). [Interne] 2007, pp.54. ⟨inria-00151285v2⟩
386 Consultations
221 Téléchargements
