Parametric Shape Optimization for the Conformation of Axisymmetric Reflector Antennas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
A shape reconstruction problem of axisymmetric radiating structures is considered. This reads as an inverse problem. The direct problem - expression of the electric field w.r.t. a given geometry - is approximated by a simple model. For the inverse problem - find the shape whose radiation has been measured - a parametric shape functional is defined for which the \emph{Free-Form Deformation} method is introduced. Two different strategies to solve numerically the inverse problem (minimize the functional) is discussed: the first one is deterministic and the other one semi-stochastic. It appears that the functional is highly multimodal. At last, a multilevel strategy is proposed for which we discuss both robustness and convergence.
RR-6210.pdf (873.29 Ko) Télécharger le fichier
inria-00151600 , version 1 (04-06-2007)
inria-00151600 , version 2 (07-06-2007)
  • HAL Id : inria-00151600 , version 2
Benoît Chaigne, Jean-Antoine Desideri. Parametric Shape Optimization for the Conformation of Axisymmetric Reflector Antennas. [Research Report] RR-6210, INRIA. 2006, pp.27. ⟨inria-00151600v2⟩
286 Consultations
145 Téléchargements
