A Comparison of Scheduling Approaches for Mixed-Parallel Applications on Heterogeneous Platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Tchimou N'Takpé
  • Fonction : Auteur
  • PersonId : 830679
Frédéric Suter
Mixed-parallel applications can take advantage of large-scale computing platforms but scheduling them efficiently on such platforms is challenging. In this paper we compare the two main proposed approaches for solving this scheduling problem on a heterogeneous set of homogeneous clusters. We first modify previously proposed algorithms for both approaches and show that our modifications lead to significant improvements. We then perform a comparison of the modified algorithms in simulation over a wide range of application and platform conditions. We find that although both approaches have advantages, one of them is most likely he most appropriate for the majority of users.
cns07.pdf (131.78 Ko) Télécharger le fichier
inria-00151812 , version 1 (05-06-2007)
  • HAL Id : inria-00151812 , version 1
Tchimou N'Takpé, Frédéric Suter, Henri Casanova. A Comparison of Scheduling Approaches for Mixed-Parallel Applications on Heterogeneous Platforms. 6th International Symposium on Parallel and Distributed Computing - ISPDC 2007, Jul 2007, Hagenberg, Austria. pp.35-42. ⟨inria-00151812⟩
151 Consultations
327 Téléchargements
