Monitoring the Neighbor Discovery Protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
While IPv6 is increasingly being deployed in networks, including ISPs, the need to monitor and manage the associated protocols increases. In this paper we focus on the Neighbor Discovery Protocol and we motivate the importance to monitor it. We also present our approach for this task together with the functionalities we provide and the software, NDPMon, that we developed.
IPv6TD07_beck.pdf (211.94 Ko) Télécharger le fichier
inria-00153558 , version 1 (11-06-2007)
  • HAL Id : inria-00153558 , version 1
Frédéric Beck, Thibault Cholez, Olivier Festor, Isabelle Chrisment. Monitoring the Neighbor Discovery Protocol. The Second International Workshop on IPv6 Today - Technology and Deployment - IPv6TD 2007, Mar 2007, Guadeloupe/French Caribbean, Guadeloupe. ⟨inria-00153558⟩
477 Consultations
946 Téléchargements
