A domain decomposition method for solving the three-dimensional time-harmonic Maxwell equations discretized by discontinuous Galerkin methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ronan Perrussel
We present here a domain decomposition method for solving the three-dimen\-sional time-harmonic Maxwell equations discretized by a discontinuous Galerkin method. In order to allow the treatment of irregularly shaped geometries, the discontinuous Galerkin method is formulated on unstructured tetrahedral meshes. The domain decomposition strategy takes the form of a Schwarz-type algorithm where a first-order absorbing condition is imposed at the interfaces between neighboring subdomains. A multifrontal sparse direct solver is used at the subdomain level. The resulting domain decomposition strategy can be viewed as a hybrid iterative/direct solution method for the large, sparse and complex coefficients algebraic system resulting from the discretization of the time-harmonic Maxwell equations by a discontinuous Galerkin method.
dghd-dolean_etal.pdf (17.57 Mo) Télécharger le fichier
inria-00155231 , version 1 (16-06-2007)
inria-00155231 , version 2 (18-06-2007)
inria-00155231 , version 3 (19-06-2007)
  • HAL Id : inria-00155231 , version 1
Victorita Dolean, Stephane Lanteri, Ronan Perrussel. A domain decomposition method for solving the three-dimensional time-harmonic Maxwell equations discretized by discontinuous Galerkin methods. [Research Report] 2007, pp.42. ⟨inria-00155231v1⟩
Collections
AMPERE
477 Consultations
239 Téléchargements
