Probabilistic Choice Operators as Constraint Combinators: Application to the Statistical Structural Testing Problem - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2007
Matthieu Petit
  • Function : Author
  • PersonId : 945280
Arnaud Gotlieb
  • Function : Author
  • PersonId : 830099
Probabilistic Concurrent Constraint Programming (PCCP) extends concurrent constraint languages by providing probabilistic choice operators. These operators have proved to be useful in implementing randomized algorithms as well as stochastic processes. In this report, we present an instance of PCCP where probabilistic choice operators are modelled with constraint combinators. This modeling allow us to deal with a new kind of problems where the probabilistic choice is only partially known. An implementation under the form of a library of SICStus Prolog is in progress. The major practical application of our work is the statistical structural testing problem in software testing.
RR-6223.pdf (321 B) Télécharger le fichier
Dates and versions
inria-00156049 , version 1 (19-06-2007)
inria-00156049 , version 2 (20-06-2007)
inria-00156049 , version 3 (25-06-2007)
Identifiers
  • HAL Id : inria-00156049 , version 2
Cite
Matthieu Petit, Arnaud Gotlieb. Probabilistic Choice Operators as Constraint Combinators: Application to the Statistical Structural Testing Problem. [Research Report] RR-6223, 2007. ⟨inria-00156049v2⟩
Collections
INRIA-RRRT
119 View
69 Download
Share
