Compositional design of isochronous systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The synchronous modeling paradigm provides strong execution correctness guarantees to embedded system design while making minimal environmental assumptions. In most related frameworks, global execution correctness is achieved by ensuring endochrony: the insensitivity of (logical) time in the system from (real) time in the environment. Interestingly, endochrony can be statically checked, making it fast to ensure design correctness. Unfortunately, endochrony is not preserved by composition, making it difficult to exploit with component-based design concepts in mind. Compositionality can be achieved by weakening the objective of endochrony but at the cost of an exhaustive state-space exploration. These observations raise a tradeoff between performance and precision. Our aim is to balance this tradeoff by proposing a formal design methodology that adheres to a weakened global design objective, namely, the non-blocking composition of weakly endochronous processes, while preserving local endochrony objectives. This yields an ad-hoc yet cost-efficient approach to compositional synchronous modeling.
RR-6227.pdf (266.37 Ko) Télécharger le fichier
inria-00156499 , version 1 (21-06-2007)
inria-00156499 , version 2 (25-06-2007)
inria-00156499 , version 3 (27-06-2007)
inria-00156499 , version 4 (05-07-2007)
inria-00156499 , version 5 (23-11-2007)
  • HAL Id : inria-00156499 , version 2
Jean-Pierre Talpin, Julien Ouy, Loïc Besnard, Paul Le Guernic. Compositional design of isochronous systems. [Research Report] RR-6227, 2007, pp.24. ⟨inria-00156499v2⟩
Collections
INRIA-RRRT
279 Consultations
226 Téléchargements
