Recasting MLF - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recasting MLF
The language MLF has been proposed as an alternative to System F that permits partial type inference a la ML. It differs from System F by its types and type-instance relation. Unfortunately, the definition of type instance is only syntactic, and not underpined by some underlying semantics. It has so far only been justified a posteriori by the type soundness result. In this work, we revisit MLF following a more progressive approach stepping on System F. We argue that System F is not a well-suited language for ML-style type inference because it fails to factorize some closely related typing derivations. We solve this problem in Curry's style MLF by enriching types with a new form of quantification that may represent a whole collection of System F types. This permits a natural interpretation of MLF types as sets of System-F types and pulling back the instance relation from set inclusion on the interpretations. We also give an equivalent syntactic definition of the type-instance, presented as a set of inference rules. We derive a Church's style version of MLF by further refining types so as to distinguish between user-provided and inferred type information. The resulting language is more canonical than the one originally proposed. We show an embedding of ML in MLF and an encoding of System F into MLF. Besides, as MLF is more expressive than System F, an encoding of MLF is given towards an extension of System F with local binders.
recasting-mlf-RR.pdf (698.15 Ko) Télécharger le fichier
inria-00156628 , version 1 (21-06-2007)
inria-00156628 , version 2 (25-06-2007)
inria-00156628 , version 3 (10-07-2007)
inria-00156628 , version 4 (03-12-2008)
  • HAL Id : inria-00156628 , version 3
Didier Le Botlan, Didier Rémy. Recasting MLF. [Research Report] RR-6228, 2007, pp.60. ⟨inria-00156628v3⟩
Collections
INRIA-RRRT
445 Consultations
626 Téléchargements
