Optimal Closest Policy with QoS and Bandwidth Constraints for Placing Replicas in Tree Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the replica placement problem on fully homogeneous tree networks known as the Replica Placement optimization problem. The client requests are known beforehand, while the number and location of the servers are to be determined. We investigate the latter problem using the Closest access policy when adding QoS and bandwidth constraints. We propose an optimal algorithm in two passes using dynamic programming.
rr-bandwidth.inria.pdf (256.05 Ko) Télécharger le fichier
inria-00156747 , version 1 (22-06-2007)
inria-00156747 , version 2 (27-06-2007)
inria-00156747 , version 3 (27-06-2007)
inria-00156747 , version 4 (28-06-2007)
inria-00156747 , version 5 (28-06-2007)
  • HAL Id : inria-00156747 , version 1
  • ARXIV : 0706.3350
Veronika Rehn-Sonigo. Optimal Closest Policy with QoS and Bandwidth Constraints for Placing Replicas in Tree Networks. [Research Report] 2007. ⟨inria-00156747v1⟩
109 Consultations
114 Téléchargements
