Virtual Retina : a biological retina model and simulator, with contrast gain control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pierre Kornprobst
Thierry Viéville
A detailed retina model is proposed, that transforms a video sequence into a set of spike trains, as those emitted by retinal ganglion cells. It includes a linear model of filtering in the Outer Plexiform Layer (OPL), a contrast gain control mechanism modeling the non-linear feedback of some amacrine cells on bipolar cells, and a spike generation process modeling ganglion cells. A strength of the model is that each of its features can be associated to a precise physiological signification and location. The resulting retina model can simulate physiological recordings on mammalian retinas, including such non-linearities as cat Y cells, or contrast gain control. Furthermore, the model has been implemented on a large-scale simulator that can emulate the spikes of up to 100,000 neurons.
Neurobiologie
RR-6243.pdf (888.74 Ko) Télécharger le fichier
inria-00160716 , version 1 (06-07-2007)
inria-00160716 , version 2 (10-07-2007)
  • HAL Id : inria-00160716 , version 2
Adrien Wohrer, Pierre Kornprobst, Thierry Viéville. Virtual Retina : a biological retina model and simulator, with contrast gain control. [Research Report] RR-6243, INRIA. 2007, pp.32. ⟨inria-00160716v2⟩
375 Consultations
963 Téléchargements
