Dynamic Noninterference Analysis Using Context Sensitive Static Analyses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This report proposes a dynamic noninterference analysis for sequential programs. This analysis is well-suited for the development of a monitor enforcing the absence of information flows between the secret inputs and the public outputs of a program. This implies a sound detection of information flows and a sound correction of forbidden flows during the execution. The monitor relies on a dynamic information flow analysis. For unexecuted pieces of code, this dynamic analysis uses any context sensitive static information flow analysis which respects a given set of three hypotheses. The soundness of the overall monitoring mechanism with regard to noninterference enforcement is proved, as well as its higher precision than the automaton-based mechanism proposed in previous work.
contextSensitiveNIA_report.pdf (451.2 Ko) Télécharger le fichier
inria-00162609 , version 1 (14-07-2007)
inria-00162609 , version 2 (14-07-2008)
inria-00162609 , version 3 (18-07-2008)
  • HAL Id : inria-00162609 , version 1
Gurvan Le Guernic. Dynamic Noninterference Analysis Using Context Sensitive Static Analyses. [Research Report] 2007, pp.61. ⟨inria-00162609v1⟩
Collections
CNRS
321 Consultations
200 Téléchargements
