Merging sensor data from multiple temperature scenarios for vibration monitoring of civil structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
The ambient temperature effect may result in limitations of vibration-based structural health monitoring (SHM) approaches for civil engineering structures. This paper addresses the issue of discriminating changes in modal parameters due to damages and changes in modal parameters due to temperature effects. A non parametric damage detection algorithm is proposed, which only assumes that several datasets are recorded on the safe structure at different and unknown temperatures, and smoothes out the temperature effect using an averaging operation.
PI-1824.pdf (471.48 Ko) Télécharger le fichier
inria-00164852 , version 1 (24-07-2007)
  • HAL Id : inria-00164852 , version 1
Etienne Balmès, Michèle Basseville, Laurent Mevel, Houssein Nasser, Frédéric Bourquin, et al.. Merging sensor data from multiple temperature scenarios for vibration monitoring of civil structures. [Research Report] PI 1824, 2006. ⟨inria-00164852⟩
224 Consultations
595 Téléchargements
