TCP Variants and Transfer Time Predictability in Very High Speed Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In high performance distributed computing applications, data movements have demanding performance requirements such as reliable and predictable delivery. Predicting the throughput of large transfers is very difficult in paths that are heavily loaded with just a few big flows. This report explores how current high speed transport protocols behave and may improve transfer time predictability of gigabits of data among endpoints in a range of conditions. In a fully controlled long distance 10~Gbps network testbed, we compare several TCP variants behaviour in presence of diverse congestion level and reverse traffic situations. We show that these factors have a very strong impact on transfer time predictability of several transport protocols.
RR_HSN07_INRIA.pdf (1.67 Mo) Télécharger le fichier
inria-00165781 , version 1 (27-07-2007)
inria-00165781 , version 2 (30-07-2007)
  • HAL Id : inria-00165781 , version 1
Romaric Guillier, Sébastien Soudan, Pascale Vicat-Blanc Primet. TCP Variants and Transfer Time Predictability in Very High Speed Networks. [Research Report] RR-6256, 2007, pp.29. ⟨inria-00165781v1⟩
Collections
INRIA-RRRT
106 Consultations
205 Téléchargements
